Configures the administrative state of an MSDP peer.
| remoteaddr | Specifies the IP address of the MSDP peer to disable. |
| all | Disables all MSDP peers. |
| vr_name | Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context. |
By default, MSDP peers are disabled.
Use this command to administratively disable MSDP peers to stop exchanging SA messages.
The following command disables an MSDP peer:
disable msdp peer 192.168.45.43
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
